Hi Mike,
For SnapAmp with Steppers the Current is set with the Microstepper Amplitude parameter. SnapAmp's full current range (Peak) is +/- 35Amps which corresponds to +/- 1024 counts. This is about 35ma per count. So for example a 5 Amp Stepper motor would be set at 146 counts of Microstepper Amplitude.
SnapAmp works differently than with microstepping Step & Direction drives like KSTEP or Geckos. It handles the position and current waveforms internally with virtually infinite resolution. But then when it finally goes to command a current there is a 35ma resolution on the commanded current. Therefore the resolution is a dependent on the Amplitude. But basically the "microstepping" resolution is quite high. For a 5 Amp motor it would be:
(2 PI) /(35ma/5A) / 4 = 224 usteps per full step
KFLOP works in units of floating point cycles (or motor poles) where a movement of 1.000 makes a complete sine wave cycle which is the equivalent of 4 full steps (1/50th of a rev).
Message: 7031 |
Date: 3/18/2013 |
Subject: Re: Snap Amp Stepper and DC Brush |
Thanks, Tom
That helps a lot.
Mike
> Hi Mike,
> HTH
> From: michaelthomasn <michaelniksch@...>
> Sent: Monday, March 18, 2013 4:38 PM
> Subject: [DynoMotion] Snap Amp Stepper and DC Brush
> Hi Tom,
> We are finally getting started on the robot arm. I ordered 2 snap amps and a kflop today for the project.
> It looks like we will be running 3 servos, and 2 steppers for now.....possibly upgrading to servos on all axis' later.
> I'm wondering how to set the stepper current on the snapamp, and what microstepping it will have.
> Mike
